What would cause the fan to stop and the compressor to keep running on a split system unit, fan would start back up after a few minutes, thermal trip on the fan motor?
| Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Not sure Jeff, but at least you had A/C today as mine was not hooked up the last two jobs and it was the same developer.
Sounds like an electronics issue |
You sure you didn't catch it while in defrost mode?
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
No, Did it several times during inspection, home owner says-its been like that for a few months, something is messed up. It's a Heil unit 7-years old.
What no A/C !!! |
No AC and un vented attics.
Tried to find serial number for the NCP but no luck. Often they are the original when I have seen them. |
Is it an older unit? Fan/limit control switch?
Indoor fan or out door fan?
He said split system so the compressor fan would be outdoors.
He didn't say compressor fan, just fan.
rramsey1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Run capacitor
Unvented attics?
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Outside fan at compressor. indoor side ran fine.
yep,metal roof over the vent holes down in cal city.Maybe Charlie will know Jeff, but I just tell them to repair.
| Testing Plumbing with a Compressor? | jleahy | Plumbing Inspections | 16 | 3/17/10 10:03 AM |
| the 65 degree question | cbrands | Inspecting HVAC Systems | 18 | 5/1/07 4:01 PM |
