Old 7/23/10, 2:31 PM
Jay Buzz Jay Buzz is offline
Please Note: Jay Buzz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Fiberglass in duct
Just bought a house built in 1979. The house has a packaged HVAC unit outside. I went to replace the filter for the first time and noticed some insulation that sits in the "air intake" portion of the unit behind the filter. At first, I freaked out, worrying that it was asbestos. I took a sample to a local lab where they identified it as glass, not asbestos. That relieves my initial concern, but then I started thinking that having fiberglass sucked into the system is not the best thing either. Any thoughts on whether this should be removed, why it's insulated in the first place, and whether I should replace it with another material.
Thanks,
Jay
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/29/10, 10:43 PM
Default Re: Fiberglass in duct
Looks like what some call fiber ductboard. Easier to work with than metal; insulation is on the inside - foil covering on the outside. Here is one link:
https://www.certainteed.com/products...hanical/317382
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 7/30/10, 1:56 AM
David A. Andersen's Avatar
No, it's just duct insulation.
It is designed for this use (back in the good old days).
If you want to rip out something, change the whole Plenum box, it's designed every which way from wrong.
BPI# 5015804
Old 7/30/10, 1:08 PM
Larry J. Michael Larry J. Michael is offline
Yep, see it at almost every house.
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Old 7/31/10, 12:10 AM
Banned
Yepp!!
And if it's covering is perforated or open mesh style, it suppresses fan or compressor noise, making the whole system much quieter.
Old 7/31/10, 11:06 AM
Not in this case though, as we can see the evaporator coil from the living room!
BPI# 5015804
Garage Dryer Duct jscaparo Plumbing Inspections 3 6/22/10 12:09 AM
Reduced return air duct mmorgan Inspecting HVAC Systems 4 6/6/07 7:39 PM
