Had two inspects yesterday one a slab on grade and one a crawl space both had leaking A-coil pans.
On the crawl space I knew that there were A/C problems before I ever enter the crawl. While making the tour of the exterior foundation I noticed a very small amount of condensate being discharged from the external condensate drain line and yesterday was a very high humidity day and there should have been a large volume of water being discharged also while passing the foundation vents I noticed cooler air discharging from the vents. My foundation tour told me two things Charley you need to pay attention to the A-coil pan and you need to look for duct separation in the crawl. I found both problems when I entered the crawl space the Supply plenum had water dripping out of the bottom and the sub-flooring was all wet Also found a 8 inch supply duct separated discharging into the crawl. Point being know your red flags as they can guide you in the right direction in detecting problems. Knowing that I had crawl space problems that were obvious to me from external to the foundation I had to make the decision to enter the crawl space which had raw fecal in front of the crawl hole. Would you have entered or deferred it??????? Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Are you defining raw in minutes or hours, was it still steaming?
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
| Health problems - house making ill ? ? | lfoster | Ancillary Inspection Services & Additional Topics | 9 | 9/16/07 6:24 PM |
| Article on Commercial and Residential Inspections and Assessment | mcyr | Commercial Inspections | 2 | 8/6/07 1:26 AM |
| Inspector Wendy's Home Inspections-Service Areas | wforsyth | Miscellaneous Discussion for Inspectors | 57 | 9/5/06 11:10 PM |
| Foundation Problems | jpope | Structural Inspections | 12 | 1/24/06 10:42 AM |
