What contractor could check the pit out …to make sure its not leaking
and the correct gas piping size and material has been used?
David
David
Got a magnet and a bottle of soapy water? :blank:
A match will work too. You may singe your eyebrows though.
Determining the correct piping size is technically exhaustive and is beyond the scope of a home inspection. On stuff like that outside, I usually give it the sniff test and may whip out my gas detector if I think I smell an odor. Other than that, move on.
