Old 3/11/10, 10:14 AM
John F. Swygert, III John F. Swygert, III is offline
Default Flex Duct Firewall Breach
Guys, I see this all the time and need some clarification. Furnace located in garage with flex duct supply and return going through the garage wall and ceiling. I know flex duct is combustable however it's approved for use as furnace ductwork. But it's my understanding that ducts from house to garage must be min. 26ga. metal. Is this a breach??? How would you write it up? Many Thanks in advance.
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/11/10, 10:33 AM
Joe Funderburk, CMI's Avatar
Default Re: Flex Duct Firewall Breach
I don't think I've ever seen it unless the furnace is in a separate room with a solid door. If it wasn't, I would definitely write it up.
Put up a photo.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/11/10, 2:50 PM
Matt Berman Matt Berman is offline
in michigan should be 26 gauge metal and have a fire damper in both supply and return
Old 3/11/10, 4:18 PM
Jeffrey R. Pope's Avatar
I see it often. . .
Flexible ducting is penetrating the garage firewall. Building standards require that all ducts in the garage and ducts penetrating the firewall be equipped with fire-dampers or constructed of a minimum of No. 26 gauge sheet steel or other approved material and shall have no openings in the garage. This condition compromises the garage firewall system and should be repaired by a qualified HVAC contractor for safety.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/11/10, 4:44 PM
I see Studor vents occasionally.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/11/10, 4:56 PM
David P. Valley's Avatar
I call out all breaches in garage walls and ceilings that divide the living area from the garage...
Flexible ducts, any type of openings in the firewall (even the seams that aren't compounded), cable and wiring openings, etc.
If the firewall is open (breached) in any way, it gets red flagged.
Old 3/11/10, 7:44 PM
Outstanding response. Thanks so much to all. Thats what i thought but I am seeing this weekly in 500K homes. Will take and add photos next chance.
Flex duct used for exhasut flue. jlybolt Inspecting HVAC Systems 11 4/6/07 12:04 AM
Flex duct length restrictions wcorbett Inspecting HVAC Systems 4 8/24/06 1:34 AM
Condo Firewall breach or no breach? tneumann Interior Inspections 13 2/3/06 11:13 AM
