Just looking for different thoughts on this one. the flex line does penetrate the casing, but the casing comes apart. At the time of the inspection the line was rubbing on the knock out. It has been called out.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Bruce -
What are you asking us?? Flex connectors don't go through walls, floors, ceilings, partitions, etc. Obviously you know this. Its in your code book; your copy of Code Check; and on the plastic bag they come in at the hardware store. So since you know this, what is it you are really asking us. |
Russel - if you researched that a bit, you will find that the manufacturers listing prohibits this practice, even when/if a grommet is used.
To say it's "allowed" in your area, is to say (simply) that, in your area, no one cares. Manufacturers listings trump local requirements, unless of course, no one cares. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
There's still one AHJ out in the boondocks whose using the 1847 codes. I think he is old enough to have been there in that position since that time. He does have some war stories to tell, but I never know if they are Civil War, WWI, WWII, Korean, Vietnam, or Bush Invasion. NACHI 2005 U.S. Member of the Year
If you can't find a listing label, here are the applicable codes. . . California Plumbing Code (CPC) 1212.0 Appliance Connectors (2) No part of such connector shall be concealed within or extended through any wall, floor, partition, or appliance housing. International Residential Code (IRC) G2422.1.2 (411.1.2) Appliance fuel connectors. Connectors shall have an overall length not to exceed 3 feet (914 mm), except for range and domestic clothes dryer connectors, which shall not exceed 6 feet (1829 mm) in length. Connectors shall not be concealed within, or extended through, walls, floors, partitions, ceilings or appliance housings. A shutoff valve not less than the nominal size of the connector shall be installed ahead of the connector in accordance with Section G2420.5. Connectors shall be sized to provide the total demand of the connected appliance. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I've got the codes, but thanks. However, I'm not a code inspector, preferring to be a generalist, so I leave the code interpretations to the AHJs, even when they (the AHJs) are past their prime.
Dan,
Just wanted to see what others thought of the split cabinet. 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com Last edited by bgraham; 5/13/07 at 6:28 AM.. |
| Gas flex line in crawl space | Richard Seay | Plumbing Inspections | 19 | 8/12/08 8:12 PM |
| Gas flex connector to furnace | jcahill | Inspecting HVAC Systems | 25 | 7/24/07 6:22 PM |
| Exposed Flex Gas Line | jfunderburk | Plumbing Inspections | 20 | 5/11/06 1:44 AM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
