Old 11/24/10, 11:37 AM
Jeffrey M. Cohen Jeffrey M. Cohen is offline
Default Flex Gas pipe to the boiler
I just did an inspection on a house that had yellow gas flex pipe going from the meter to the boiler and the tankless water heater. I feel this should be black pipe. Also there was no drip leg on the boiler. Any thoughts?
flex-gas-pipe-boiler-dsc_1752.jpg   flex-gas-pipe-boiler-dsc_1753.jpg   flex-gas-pipe-boiler-dsc_1766.jpg   flex-gas-pipe-boiler-dsc_1768.jpg
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/24/10, 11:39 AM
Jeffrey R. Pope's Avatar
Default Re: Flex Gas pipe to the boiler
This is CSST. Perfectly acceptable for this application. Drip legs are not required by all jurisdictions.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/24/10, 12:37 PM
Joe Funderburk, CMI's Avatar
The piping should be bonded from the meter to the service entrance ground bus or ground rod.
What type of flooring is the piping coming through in the last picture?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/24/10, 12:54 PM
Sean Fogarty's Avatar
Read the manufacturers specs if you not sure. They are online and free most of the time.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Thanks
Old 11/24/10, 1:25 PM
Good bonding illustration
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/24/10, 1:52 PM
David C. Macy's Avatar
Joe nice pic, mind if I add to my collection?
I think you guys covered it pretty well. Bond due to lighting strikes and check the manufacturers instructions. You guys are good!!
Old 11/24/10, 3:18 PM
Matt Berman, CMI Matt Berman, CMI is offline
I see no union between the gas shut off and the burner gas control ,looks like a drip leg inside .
Old 11/24/10, 4:22 PM
I put it up there for anyone who wants it. Thanks for asking.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/24/10, 10:40 PM
Concrete
Old 11/24/10, 11:06 PM
Brian E. Kelly's Avatar
Originally Posted by jcohen2 View Post
Concrete
Needs a sleeve then
Old 11/25/10, 8:27 AM
Originally Posted by bkelly2 View Post
Needs a sleeve then
That's right...
Larry Kage, CMI
231 929 3525
Old 11/27/10, 2:46 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Don't believe that CSST is supposed to be buried in concrete. The installation instructions for Tracpipe on page 46 states.
"When piping is installed underground
beneath buildings, codes require that the
piping shall be encased in a conduit
sealed inside of the building and vented
above grade to the outside. The conduit
shall be designed to withstand the superimposed
loads. NO FITTINGS OR COUPLINGS
ARE PERMITTED BENEATH
BUILDINGS."
Old 11/30/10, 11:13 AM
Images for how piping should be run underground.
flex-gas-pipe-boiler-underground-piping.jpg flex-gas-pipe-boiler-underground-piping-2.jpg
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/1/10, 10:00 AM
rsmith24 rsmith24 is offline
Where the regulator for the meter? Outside? I've never seen a meter without one.
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
