Old 1/3/07, 9:45 PM
Christopher Rich Iii Christopher Rich Iii is offline
Default Flexable yellow gas pipe through walls??
Hello Everyone.. I inspected a home today with a two zone heat system. The attic heat system had the flex tubing running down through the wall into the basement(attached to black pipe from street). It this type of application allowed? I could not see if it was supported or anything. My thoughts were it was not supposed to go through walls or floors(hard pipe only)? Any help would be appreciated.
Chris
Old 1/3/07, 9:57 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Re: Flexable yellow gas pipe through walls??
Here is a link for CSST gas piping.
http://209.85.165.104/search?q=cache...ient=firefox-a
Old 1/3/07, 10:00 PM
This link has some good information.
http://www.patternstream.com/Case_St..._catid19_e.pdf
Old 1/3/07, 10:04 PM
Here is the picture from the attic.
Old 1/3/07, 10:07 PM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
Far as I know its OK. The only place I've heard its not supposed to be is, for example,...going through the knock-out hole in the metal cabinet of the furnace. That portion is to be hard piped.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 1/4/07, 2:01 AM
Robert J. OConnor's Avatar
CSST should also not be exposed to physical damage, and the connectors shouldn't be buried in the wall. You also need very large/oversized stud protection plates when the piping is close to the finished wall. That one is missed all the time.
JMO & 2-nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
something else to chew on john bubber Structural Inspections 706 4/25/12 7:13 AM
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 4:55 PM
