Old 4/7/08, 1:44 PM
John Evans John Evans is offline
Default Flue Connection
First time I have encountered this type of flue connection, appears to be some type of baffle system. The entire flue was rusted with voids, and I was reading CO2 levels with my momoxide detector. Note the open bottom of the "Box". Any ideas for this one? The boiler is 76 years old, steam system, recommended replacement.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 4/7/08, 6:25 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Default Re: Flue Connection
I believe you should call it out to be replaced.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 4/7/08, 7:12 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
worth repeating.
Old 4/9/08, 2:14 PM
I recommended replacement of the entire system. Still curious regarding the purpose of the "box", maybe a prehistoric damper?
Old 4/9/08, 3:38 PM
Russ L. Myers, CMI Russ L. Myers, CMI is offline
The "box" as you refer appears to be a draft diverter. many vintage heating systems and hot water heaters did not have a built in draft diverter.
Old 4/9/08, 7:19 PM
Russ,
Thank you for the response. So, the bottom is supposed to be open?
Old 4/10/08, 11:23 PM
Yup.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Defective Heat Exchanger, Flue Connection, etc jevans Inspecting HVAC Systems 1 2/12/08 10:38 PM
Flue Connection mkiss1 Inspecting HVAC Systems 5 1/9/08 8:51 PM
Flue Size when size matters? msylvester Inspecting HVAC Systems 14 1/20/07 11:29 PM
Fireplace-metal insert to metal flue connection sfalvey Interior Inspections 5 10/30/06 11:25 PM
Flue vent connection for water heater hspinnler Plumbing Inspections 11 5/11/06 9:56 PM
