I ran into this today. What type of covering is it? Is it asbestos?
Thank you. Last edited by mashburn; 2/6/08 at 6:29 AM.. |
Looks like it, have it tested to be sure.
It's not a covering, it's the actual vent. It is called Transite and it does contain asbestos, although that's not an issue.
These vents will crack over time. Even minor cracks can allow heat and/or exhaust to escape. For this reason, you should always recommend replacement of these Transite vents with modern steel B-vents. There's no need to recommend "further evaluation" or "testing" of any sort - just replacement. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 9/16/07 at 6:07 PM.. |
I've heard about products that may encapsulate this type of chimney in attic space if it truly is asbestos containing material.
STATEN ISLAND HOME INSPECTIONS WWW.SIHOMEINSPECT.COM LIC.#16000002260 718-987-1759 917-797-3917 SERVING DOWNSTATE NEW YORK |
Again. The asbestos is not the issue. The issue is cracking of the vent. The vent pipe should be replaced, not modified.
Jeff,
Do you have a cite for the prevalence of cracks in Transite vent pipes? Thanks |
Just the age of the vent pipe and that it is single wall is enough to have it replaced.
Thank you Jeff, and All for your input. I recommended that it be replaced.
| Flue through bedroom closet | rwills | Interior Inspections | 7 | 2/1/08 6:40 PM |
| How many gas/oil appliances can vent into 1 flue? | jberthiaume | Inspecting HVAC Systems | 11 | 10/17/07 10:09 AM |
| Cracked flue tile | bknowlton | Inspecting HVAC Systems | 6 | 2/1/07 11:37 PM |
| Flue Size when size matters? | msylvester | Inspecting HVAC Systems | 14 | 1/20/07 11:29 PM |
| Gas Log Flue venting height. | lagudo | Inspecting HVAC Systems | 34 | 4/7/06 1:42 AM |
