Old 10/25/09, 5:02 PM
Rick A. Hunt Rick A. Hunt is offline
Default Flue pipe running through cold air return
Anybody ever see this?
Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America)
Old 10/25/09, 5:16 PM
Jeffrey R. Pope's Avatar
Default Re: Flue pipe running through cold air return
Cold-air return? If you're referring to the return-air compartment, the flue should not be there. It looks like a closet to me. Has this been modified to be a return-air compartment?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/25/09, 9:53 PM
cjustason's Avatar
cjustason cjustason is offline
We used to line combustibles with sheetmetal sometimes when space was a problem. You sure its actually in the r/a duct?
Old 10/25/09, 10:19 PM
Yes, I'm positive its the cold air return. Now if its running straight through it or its framed out I cant really see. I do know when I used my gas sniffer I was getting readings in the cold air return. I refered it to a hvac guy cause of the readings.
Old 10/25/09, 10:39 PM
Bob Elliott's Avatar
That is a major health /safety issue and I would call to shut down that unit till fixed (rerouted)
Are they using joist space as part of the return?
Old 10/25/09, 10:55 PM
Keith Runquist, CMI Keith Runquist, CMI is offline
Send a message via AIM to krunquist
Saw this once. So happened that there was a gas leak at the house so I called the gas company during the inspection for repairs or shut down. While they were there I howed it to the the guy. He said "good call" but in this case they had used some sort of apporved sleave for the flu pipe. May not be approved everywhere and the guy said it's hard to tell if it's done properly but in this case he was familiar with the house and the installation. I still called it out and told the client to get approval in writing. I'll call it out if I ever see it again too.
Keith Runquist, CMI
Old 10/26/09, 11:10 AM
Henry Martinez Henry Martinez is offline
Please Note: Henry Martinez is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is a cold air return! its panned in using the joists to pull return air, both terms have been since the birth of its use.
the closet is a place where clothes or toilet is called ?
modified , no! it only has a flue pipe going through it. which is a big NO NO!
Old 10/26/09, 1:19 PM
Thanks for the help everbody!!! Its so nice to have this board to bounce stuff off of.
Gas Water Heater Flue Pipe Connected To Plumbing Vent Pipe bwilliams Plumbing Inspections 6 8/7/09 10:32 PM
Cold air return bemelander Inspecting HVAC Systems 8 8/7/07 11:41 PM
Water supply pipes and drain pipes running through return air ducts? aharper1 Inspecting HVAC Systems 3 9/26/06 12:09 PM
cold air return in basement? bmargiotti Inspecting HVAC Systems 10 1/24/06 5:51 PM
Cold air return and electrical romex dmacy Electrical Inspections 12 1/3/06 6:16 PM
