Old 1/8/06, 6:10 PM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Default Flue residue questions
Noted this residue on yesterdays inspection. Newer boiler ( 1990 ) venting into "Class A" type 8" chimney. Same age boiler mate water heater. Wondering if old unit ( water heater ) was gas and that's why the larger chimney. Would you write this up as "possible" orphaned type chimney? Or how? Thanks!
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 1/8/06, 6:57 PM
Steve McIntire's Avatar
Steve McIntire Steve McIntire is offline
Default Re: Flue residue questions
The Boiler/ water heater flue is corroded at ______ location. Recommend repairs by licensed HVAC contractor.
Old 1/8/06, 8:18 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
I agree
Was there any kind of a rain cover over the flue when it exited the roof of the house?
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 1/8/06, 8:27 PM
rwand1 rwand1 is offline
Definetly water entry/condensation causing corrosion. Recommend further evaluation by licenced heating contractor.
The chimney elargement may be too large causing poor draft, resulting in condensation forming in upper area of chimney.
Raymond Wand
Alton, ON
Old 1/8/06, 9:52 PM
Thanks guys, yes there was a S.S. cap which was stained quite dark at top. Makes me wonder if the orgional unit might have been fuel oil fired. No sign of underground tank was noted though. ( 1973 home )
John Springstead
1-231-544-6001 fax
Old 1/9/06, 7:18 AM
jrupert jrupert is offline
The damage you see was caused by the flue damper pictured. This damper has 4 bi-metal vans that close when they are cool and open when they become warm, this did create an energy saving of approx 8% in it’s day. However all most all of the manufactures years ago took a position that they were damaging to the flue and furnace and thus should be removed. I vaguely recall that they may even been a government recall on all of them due to failure and that they are not equipped with any safety device should they fail
The damage occurs when the damper closes (it only block 80%) trapping still hot flue gasses in the furnace, these gasses cool and condense, they are acidic and corrode the furnace, the 20% not trapped will condense in the flue, in your picture the condensed flue gas is leaking though the joint connections damaging the pipe
John Rupert
Accurate Property Inspections
Solitaire Heating & Cooling
CSG Training (HVAC Training & Consulting)
Old 1/9/06, 7:23 AM
If it is former oil fired unit and carbon deposits are still in flue the condensation from gas will mix with carbon and form carbonic acid which is corrrosive.
Raymond Wand
Alton, ON
Old 1/9/06, 7:26 AM
Also I don't like the junction box sitting where it is.
Raymond Wand
Alton, ON
How many gas/oil appliances can vent into 1 flue? jberthiaume Inspecting HVAC Systems 11 10/17/07 10:09 AM
Flue Size when size matters? msylvester Inspecting HVAC Systems 14 1/20/07 11:29 PM
Some good questions that always need answers jtedesco1 Electrical Inspections 5 6/16/06 9:10 PM
Gas Log Flue venting height. lagudo Inspecting HVAC Systems 34 4/7/06 1:42 AM
