Ok, I think I have found out the secret to attaching photos. I think?? OK, boys and girls,here we go. I need all the help I can get on this one. As you look at the picture you will see two gas hot water heaters combined to go out the ceiling throught one single lining flue. Also, there is a flue from the direct vent fireplace with zero clearance to the ceiling board and the back of the fireplace is directly against the hotwater heater. This all in an exterior closet of about 4'x3'. the ceiling is covered with masonite. This is all in a 2 million new house.
What you don't see is the "t" for the TPR valves, and the flex pipe going directly into the housing for the gas fireplace. Give me code and comments, PLEASE!![ |
grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
I wish I could have gotten a better picture, but as the beginning say, I just figured out how to get the picture in the message. With only 250k allowed, it's hard to get a good picture. Anyway, as the message says, the two hot water heaters are vented into one stack of the same size and out the building. The flue pipe is single wall and directly against the masonite ceiling.
Two appliances cannot be connected or Tee together without an increase in size of the flue pipe. ( size of the trunk line+ 50% of the second pipe.) Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Thanks for the inputs.
What is the clearance requirement for single wall flues? Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| flues and windows. | tdietrich1 | Inspecting HVAC Systems | 7 | 9/22/07 10:18 PM |
| Question on chimney flues and insulation | rchorey | Inspecting HVAC Systems | 2 | 4/6/07 6:57 PM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 5:08 PM |
| Multiple flues | dmacy | Inspecting HVAC Systems | 2 | 2/6/06 6:35 PM |
