Old 8/25/10, 8:00 PM
David C. Macy's Avatar
Default Fogged Glass/Gas Fireplace
New construction
73 degrees in house with air conditioner running.
Factory built fireplace vented to exterior through side wall.
Gas operated by a wall switch.
Glass fogged over when testing. Is this normal?
Thanks!!
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/25/10, 8:02 PM
Michael Larson's Avatar
Default Re: Fogged Glass/Gas Fireplace
Originally Posted by dmacy View Post
New construction
Thanks!!
Yes,
It should clear after a few minutes of operation.
There is a lot of water vapor when you burn gas.
Michael Larson
Hudson, WI
Old 8/25/10, 8:09 PM
Thanks!!
Old 8/26/10, 12:38 AM
Russel Ray's Avatar
Yes, but that fog also has a small amout of sulfuric acid in it, so after many years the glass can be etched so badly that you have to replace the glass if you want to see the fire in the fireplace.
Old 8/26/10, 4:17 PM
William Warner's Avatar
William Warner William Warner is offline
Flue gas emissions from 'fossil' fuel combustion
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 8/27/10, 12:51 PM
John Safstrom John Safstrom is offline
Please Note: John Safstrom is a non-member guest and is in no way affiliated with InterNACHI or its members.
Saw the same thing yesterday on an inspection. It cleared in a minute. You can see the fog lift from the bottom when it heats up.
Old 1/26/11, 9:34 AM
Robert Manley Robert Manley is offline
Yes, But I have seen many of these that do not clear up after several minutes even as long as 15-20. I also have noted and spoke to a fireplace technician that some of the double pane glass gas fireplaces have seals(?) between the panes and that if the seal is bad, you can get fogging and condensation between the two panes. Thought is made sense since I have seen what appears to be air movement and haze fogging around the corner after running the fireplace for a long time. Evidently the warmer air hitting the colder air of the outer pane. Ever heard of this? Was not sure!
Robert Manley
7 County Home Inspection, LLC
612-919-3844
www.7countyhomeinspection.com
Thermal Infrared Certified
Old 1/26/11, 9:37 AM
So, My question is what is the problem if the fireplace continues to show fog that does not clear. And is it possible to be in between the two panes of glass?
Robert Manley
612-919-3844
Old 2/3/11, 2:14 PM
jhugenroth jhugenroth is offline
Please Note: jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
No problem really, as it does not affect the fireplace operation. It's more of a cosmetic issue. I point it out to customers, and let them know the glass can be replaced if they want.
Hearth size??? jcampbell Inspecting HVAC Systems 32 6/1/08 1:56 PM
The Rumford Fireplace: Safety vs. Efficiency mbryan Interior Inspections 2 4/28/08 4:38 PM
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
Direct vent fireplace fogged glass scosta Inspecting HVAC Systems 9 4/15/06 12:28 PM
