Old 4/21/10, 3:18 PM
Eragorn Northe Eragorn Northe is offline
Default fresh air vents?
I have seen how the fresh air intake for the newly installed furnaces work in a house, this is different in this condo, it has a vent coming up from the crawl space under the condo.
is this something newish?
Eragorn Northe
Der Hous Inspector LLC
cell-306-684-1748
www.derhouseinspections.com
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/21/10, 7:23 PM
James E. Braun, CMI's Avatar
Default Re: fresh air vents?
If it is coming from the crawlspace, I would not call it fresh air. It really should be the other way around. Conditioned air should be pulled through the crawlspace.
Old 4/21/10, 7:40 PM
Is that an enclosed space? Is that vent their attempt at combustion air?
Larry Kage, CMI
231 929 3525
Old 4/21/10, 8:34 PM
In Canada when putting in a new furnace in a newly build home, because they are being build more air tight, and in a closed off room, they must have a fresh air supply.
Eragorn Northe
cell-306-684-1748
Old 4/21/10, 9:30 PM
Marcel Gratton's Avatar
Most likely that combustion air intake extend to the outdoors through the crawlspace.
Did you observe air intakes at exterior walls?
On The Level Inspection
Gatineau, Québec
Old 4/21/10, 10:40 PM
only the the dryer vent
Eragorn Northe
cell-306-684-1748
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Interesting Roof Vents cevans Exterior Inspections 1 6/19/09 2:03 AM
Vents in siding?? sfalvey Exterior Inspections 7 11/17/07 9:58 PM
Question on Fresh air ducting rcross Inspecting HVAC Systems 10 1/25/06 1:25 PM
Gable Vents mpedeferri Structural Inspections 13 1/25/06 7:05 AM
