Dawn Borrett is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hello,
We are in the process of finishing parts of our basement. While preparing for construction, I noticed a small patch of frost on the warm side of the vapor barrier where it covers a stud. There is fiberglass insulation between the studs, then the poly barrier. The stud is very cold to the touch. This part of the basement wall is above ground approximately 1.5 feet. I live in Minnesota and it has been below zero for several weeks. Is this simply a humidity issue inside the basement that I need to resolve? Is there something I should do to prevent further frost before I lay sheetrock here? Any help is appreciated. Thank you! |
I live in Hudson, WI and have been seeing much more frost on interiors than usual due the extreme cold. For example: In my own home I had to turn the automatic humidifier way down to avoid heavy frost on my double pane insulated windows. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Check your humidity level and try to maintain it in the 30%-50% range.
I took your advice and read up on the articles from the DOE. I then did a quick 'feel' for drafts along the sill. There is a definite slight draft there! I will do as suggested and pull off the barrier to locate the leak and seal. Looks like it should be an easy fix (if I can find the leak). Thank you so much for the quick response!
The house does have humidity controls, but as the temps dropped, I raised the humidity. Clearly, I need to get educated
I always thought it was the other way around, but then again, I am in the humid summers DC area!
Humidifier Settings, Installation and Maintenance Tips
During extremely cold weather, your home loses humidity to the outdoors and may drop to as low as 10%. The American Society of Heating, Refrigerating and Air-Conditioning Engineers (ASHRAE) recommend that your home maintain a humidity level between 30-60%. As the exterior air temperature changes so do the optimal interior humidity levels of your home. As the temperature drops outside so must the humidity levels in your home. If the weather man calls for a prolonged cold snap be sure to lower your humidistat. . Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Wow was I off! Learning everyday! Here are a couple of sites I came across..
http://www.blueflame.org/datasheets/humidity.html http://www.home-smart.org/how_your_h...ef=795:HYHW_LN |
These were great articles. Thanks! It was interesting to learn of all the potential sources of major humidity that I hadn't really considered.
One more thing. I just wanted to thank everyone for the help out here. This probably isn't meant to be a resource for the average home owner. After reading some of the boards however, it seemed like you would understand the problem and have some solutions. Again, many thanks.
Jeff: Had a quick look at both these sites. Saw 2 glaring errors in the gas assoc sheet.......these folks sell gas and are not building scientists nor technicians. The second site looks all right but is at the homeowner level. |
Just wondering - what were the errors? I tried to look up on ASHRAE, but I think you have to be a card carrying member...
(2) "Generally, older homes have an average of one to two ACH. Tight, new homes or older homes which are sealed may replace air only once every two hours or more (or .5 ACH)." A "tight" new home will not be tight if it changes air naturally at 0.5 ACH. As a matter of fact, in northern climes during cold weather snaps, the house will be overdried, there will be nosebleeds, people will be getting shocks from door handles and energy bills will be high!! A truly tight home will change air naturally about every 20-24 hours without door openings and mechanical ventilation. These things I know from personal experience: (1) The first time I tried to make a house airtight was 1977 (2) I was a "certified" (recognized by US gov) energy auditor in 1981. (actually took the course (7 days) at Bowdoin College , Brunswick, Maine where INACHI member Marcel Cyr has done a lot of construction work) (3) Bought a blower door in 1981 to do air leakage control work (4) was trouble-shooter, researcher, site advisor for Canada's R2000 Low Energy house program for 8 years in the 1980's-90's. During this period 2 of my clients were named Canada's R2000 "Builder of the Year". PS: I have addressed only the 2 items I noticed in my first 30-60 second glance at the document....there may be more! Last edited by Brian A. MacNeish; 1/28/09 at 9:54 PM.. |
| Frost in attic | shand | Interior Inspections | 26 | 2/5/09 11:27 AM |
| Jack Frost | jfrederick | Plumbing Inspections | 7 | 1/6/09 3:43 AM |
| Frost wall and mold | tclement | Structural Inspections | 3 | 3/14/07 10:33 AM |
| Frost, Ice, & Condensation @ RIM JOIST | Sean M. Jeric | Inspecting HVAC Systems | 4 | 2/5/07 6:56 PM |
| Frost in attic | mashburn | Structural Inspections | 12 | 1/29/07 5:18 AM |
