Old 9/29/08, 6:11 AM
Jack Moreck Jack Moreck is offline
Default Furnace 18" Above Floor
Can anyone tell me exactly when the building or gas "code" was adopted that required gas furnaces and/or water heaters to be installed 18" above a residential garage floor ? If this "code" or the existance of a health/safety concern was not called out in an inspection, might an inspector be liable for an omission ? What if the "code" was not in effect when the home was constructed ? Can a gas supplier attempt to enforce the new code on a home that was built before the code was enacted ? I think you can see my predicament !!! Any help or advice would be appreciated.
Old 9/29/08, 6:38 AM
David P. Valley's Avatar
Default Re: Furnace 18" Above Floor
Even though it's great to know your local and national codes when inspecting a home, it's not required to know all codes, especially if you're not a code inspector.
When I perform home inspections on the older homes, I don't break out my code book to determine when a specific code was enacted. All issues (within a home) will get written up, and there will be NO code reference's to back up my findings. I simply write up issues because they are defective, becoming defective or are simply a safety issue.
It sounds as if you have someone stepping on your toes. Did you not write up a furnace for having it's burners below the required 18" height in a garage?
Old 9/29/08, 8:16 AM
Michael R. Boyett's Avatar
Jack, keep in mind the wording of the IRC and Fuel Gas Code regarding this.
2003 IRC G2408.2 (305.3) Elevation of ignition source. Equipment and appliances having an ignition source shall be elevated such that the source of ignition is not located less than 18" above the floor in hazardous locations and private garages."
The inherent design of the equipment may very well have the pilot light, ignition coil or other means of ignition already 18" above the bottom of the equipment and would, therefore, not require the equipment to be elevated. The 18" is to the source of ignition, not the bottom of the equipment. That may or may not help with your dilemma.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 9/29/08, 8:17 AM
Jack, it would be a safety hazard regardless when the code was adopted, IMO.
Larry Kage, CMI
231 929 3525
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 5:03 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
