Comfortmaker With an RPJ Heat Exchanger
Model G-U 400100-12M-P Serial # 0000211401-L26-009 Rick Kie |
I think Tallen posted it. Comfortmaker (International Comfort) uses the first letter for the month (skipping I) and the first two digits are the year. So could be 2000 |
It says to use the first letter followed by 9 numbers. I see no letters
There is excessive rusting for it to be a 2000 I think Rick Kie |
You could try the site called furnace compare |
I'll Try that thank you
Rick Kie |
If I reverse the serial number to 009-L26-0000211401, then it matches the Comfortmaker serial numbers I have in my file, seeming to indicate a November 1992 or November 2002 unit. It wouldn't be 1962, 1972, or 1982 because they used a different serial number system in those years. Combine that with construction date of the house or manufacture date of other appliances and see if you can match it up. NACHI 2005 U.S. Member of the Year
Thanks for your input Russel.
The house was built in 1950 there are moisture issues in the basement and there is 3/8 of an inch of rust right outside burner tubes with 1/4" layer inside the tubes. The report has been sent I had to write unable to termine the age. Clearly its time for a new heat exchanger at least if not a new furnace. Rick Kie |
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 28 | 10/21/07 6:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 2:56 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 8:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
