I know whats missing but want to know if it is that obvious to everyone else.
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
LOL Well a flue pipe is a option isn't it
How do you forget that!!
that thing exhausts combustion gases into the attic?
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Safety is sooo overrated!!
The attic is the same as the outdoors, right?
I kept looking at it and saying where's the vent pipe,where's the vent pipe
Here is a few more pics
Good for you David in your thinking.
you were thinking correctly. I take it there was no roof cap piping, where this thing should have connected to? |
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 Last edited by dgarton; 7/16/11 at 11:53 PM.. |
Vacant for 8 months huh? I guess that is because the previous owners are dead.
Pretty obvious the flue was never connected but what about the safety pan I can not see in your pic did it have a drain connected or a 24 volt safety switch??????
No Flue is pretty bad ...
What about the small PVC pipes. The primary and secondary condensate pan stubs connect to one 3/4 PVC drain line (no trap or vent, and they shouldnt connect to the same drain line ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 7/17/11 at 9:30 AM.. |
A few years back, I was performing a home warranty inspection. The gas furnace was venting into the attic as well. The builder did not want to address the issue at that time, I told the owner to turn off the furnace. The builder said it could wait until the next day. His justification was, "it is a well vented attic".
I informed the builder we could call the local fire department and have their HazMat team take a look. He ended up changing his mind and brought out the HVAC sub to correct the issue right away. |
| Acceptable Furnace Install in Sealed (foamed) attic | kweiss | Inspecting HVAC Systems | 40 | 3/9/11 9:13 PM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| Propane gas to attic furnace | brepanshek | Inspecting HVAC Systems | 5 | 2/21/07 5:06 PM |
