Old 2/7/07, 3:33 PM
John B. CORDELL John B. CORDELL is offline
Default Furnace in attic (High Efficient)
Question:
Can a high energy efficent furnace be installed in an attic that is not heated.
Old 2/7/07, 3:35 PM
Stephen W. Stanczyk's Avatar
Default Re: Furnace in attic (High Efficient)
Yep.
Stephen Stanczyk
Old 2/7/07, 3:41 PM
One of my inspectors just had a call from a client he did an inspection for last Spring. She said her condensation line freeze and she was told it was against code to install a high efficent furnace in a iun heated area? HELP
Old 2/7/07, 5:14 PM
David A. Andersen's Avatar
Where do you live, Cincinnati, AK?
Old 2/7/07, 6:18 PM
I live in Cincinnati
Old 2/7/07, 7:00 PM
The furnace was a frigidare. I spoke with a compnay here in town and they claim you can install in attics. Anyone know any thing about the brand.
Old 2/7/07, 7:00 PM
Old 2/7/07, 7:01 PM
John
Check your local codes first. I don't know of any HVAC Manuf. that restricts the installation of H/E condensing type (90%+afue - upflow or horizontal) furnaces in Attics, Crawls or Basements. Installation requirements may differ some, but not drastically.
The freezing of the acidic condensate from the PVC flue vent piping and into the drain is most likely an installation mistake (ie: no slope, sloping the wrong way, blockage or weather ???). Call and HVAC Contractor to check it out.
Old 2/7/07, 7:46 PM
Thanks for the reply
Old 2/8/07, 10:44 AM
Freezing condensate should not be an issue if the unit is properly installed.
It is often considered that the flue pipe should slope towards the outside so the water will drain out. This is not the case, it should slope back towards the unit so the condensate can be stored in the furnace where the heat is.
When the furnace is in operation, everything is hot and there should be no problems with freezing condensate.
The drain line should be installed so that there is no reservoirs of standing condensate in the cold space. If traps are necessary, they should be in a location where they won't freeze.
Old 2/8/07, 9:43 PM
David P. Valley's Avatar
Very good David. I was just about to post a similar reply.
I see no problem with this install whatsoever.
Old 2/9/07, 9:51 PM
Keith R. Braun's Avatar
Keith R. Braun Keith R. Braun is offline
The following comes from an ICP (Heil) installation manual for condensing gas furnaces: Special precautions MUST be madeif installing furnace in an area which may drop below freezing. This can cause improper operation or damage to the equipment. If the furnace environment has the potential for freezing, the drain trap and drain line must be protected. Use 3 to 6 watt per foot at 115 volt, 40 degree F self regulating shielded and waterproof heat tape. Wrap the drain trap and drain line with the heat tape and secure with ties. Follow the heat tape manufacturers recommendations.
Old 2/10/07, 10:43 AM
Everyone. Thanks for all the information. This was what I have been trained for for the past 15 years also. It is always good to here back from fellow inspectors. After a while its easy to start second guessing yourself after all these years.
Old 2/10/07, 10:45 AM
tdietrich1's Avatar
My high efficiency has a water trap. It's always filled with water, go figure. Is this not needed with an attic installation? Because I can see this quickly freezing.
tom
Old 2/10/07, 7:02 PM
Condensate is hot. So long as it doesn't freeze or thaws out when the unit comes back on, it should work.
Horizontal Furnace in Attic Anthony Joseph Inspecting HVAC Systems 5 10/12/07 10:08 AM
Supply Plenum Mounted High in Attic Skip Erwin Inspecting HVAC Systems 6 4/7/07 11:07 AM
Propane gas to attic furnace brepanshek Inspecting HVAC Systems 5 2/21/07 6:06 PM
Cat 1 Furnace in attic wdecker Inspecting HVAC Systems 2 6/14/06 2:28 AM
90% efficient furnace venting jrupert Inspecting HVAC Systems 2 2/16/06 4:54 PM
