Is there away you can help with age of furnace
Luxaire WDLM014517 Thankyou Bryson Bumstead B.D.B. Home Inspections bryson@bdbhomeinspections.com bdbhomeinspections.com |
| Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Fraser, Johnston and Luxaire were purchased by York in 1980. York recently changed their serial nomenclature, so the old cheat sheets will not work in decoding anything manufactured after 2005. In this case, the NEW serial decoding is used. The new decoding is MUCH easier than the old. First letter - specifies CITY of manufacture. W - Witchita, Kansas Second number - tells you the THIRD digit of the year of manufacture. Third letter - specifies month of manufacture. (12 Letters) A-January B-February C-March D-April E–May, F-June, H-July. Fourth number - specifies fourth digit of year of manufacture. When there are three or four letters at the start, the third letter is the year. Y is 1991, A is 1992, etc. The remaining numbers are just sequential numbers, and can be ignored. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I don't see it listed in Preston's 1960-2005 Edition. No unit model numbers that begin with the letter "W".
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
| Miller Furnace codes | Unregistered | AskNACHI.org Inspection Questions Forum | 2 | 8/4/11 9:57 PM |
| Miller Furnace codes | Unregistered | AskNACHI.org Inspection Questions Forum | 0 | 8/3/11 9:34 AM |
| Rheem oil furnace recall | bwiley | Inspecting HVAC Systems | 3 | 1/29/09 7:45 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 2:56 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
