Dale Trach is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone see an issue with a high efficiency furnace exhaust being so close to the heat pump?
The heat pump was installed two years after the completion of the house. I'm thinking theoretically, the furnace and heat pump should not be operating at the same time to cause coil corrosion. Last edited by Dale Trach; 4/27/11 at 12:15 PM.. Reason: Can not attach image |
| York Heat Pump | Summer House | Inspecting HVAC Systems | 7 | 2/21/07 9:13 PM |
| Carrier heat pump fires? | lprinzi | Inspecting HVAC Systems | 3 | 10/12/06 7:31 PM |
| Installing new heat pump with existing furnace | wlmoss | Inspecting HVAC Systems | 6 | 5/14/06 11:23 AM |
| Exhaust fan in room with gas water heater and furnace | jweinberg | Inspecting HVAC Systems | 7 | 2/18/06 1:23 PM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 9:17 PM |
