Old 9/7/08, 2:51 PM
Al D. Bolt Al D. Bolt is offline
Default Furnace flue
What is the purpose of an opening like this between the furnace unit and the flue pipe?
Thanks.
Old 9/7/08, 3:02 PM
Banned
Default Re: Furnace flue
Thanks.
This draft hood allows the draft over the fire to remain fairly constant by allowing house air into the flue system when winds are high and/or the stack effect is creating higher negative flue pressure than recommended by the manufacturer for good appliance operating characteristics. In an oil system, there would be an adjustable device in the flue pipe called a barometric damper to balance the flue pressures to what is recommended.
By adjusting/balancing the negative flue pressures, the fire flames are not distorted by the high draft (better, more complete combustion) and.......the flue gases are not drawn through the heat exchangers at higher velocities that will reduce heat transfer time from the flue gases to house air/heating water resulting in lower system efficiencies.
Old 9/7/08, 3:03 PM
Jeffrey R. Pope's Avatar
Draft hood. . .
It's necessary to aid in venting of the appliance. Standard practice for gravity-type vent systems. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/7/08, 3:36 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is that a Consolidated brand furnace?
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
Furnace Flue Skip Erwin Inspecting HVAC Systems 10 3/8/08 10:54 AM
Gas Furnace Flue Skip Erwin Inspecting HVAC Systems 1 9/6/07 9:24 PM
Oil Furnace Flue Clearance jfunderburk Inspecting HVAC Systems 3 2/28/06 7:17 PM
