I inspected a new construction condo in Chicago today, The new Carrier Furnace was installed upside down, and because it was installed upside down it had 5 90 elbow in the vent pipe.
Does anyone have any information about if Carrier unit can be installed upside down. I have emailed Carrier but no reply yet. Thank for the help Michael Michael Cotten Cornerstone Home Inspections Inc www.cornerstonehomeinspect.net cornerstone235@aol.com |
There are "down flow" FAU's, but it sounds like you've described an improper installation. Do you have any pictures?
Five 90 degree elbows? I believe each elbow is the equivalent of 20' of horizontal run. That means you have in theory 100' of exhaust vent. I also don't understand how a furnace can be installed upside down without changing the burners and heat exchanger othewise it would not be firing properly, et ceteras.
Michael,
Thanks for the link. Very informative. Michael Michael Cotten Cornerstone Home Inspections Inc www.cornerstonehomeinspect.net cornerstone235@aol.com |
carrier does make multi posistional furnaces they can be flipped for any postion upflow,downflow,horizontal,but the flue is able to be moved too sounds like maybe installer error
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 24 | 10/21/07 7:26 PM |
| Hot Air furnace installed on wood floor | dbelmont | Inspecting HVAC Systems | 4 | 7/24/07 9:22 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 3:56 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 9:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
