Old 4/24/07, 12:25 AM
dsmith1 dsmith1 is offline
Question Furnace Location?
Found an electric forced air furnace installed in a garage today to heat the house. Does not seem right to me. My concern is the furnace pulling in carbon monoxide, from the car, through any openings in access panels or joints in ducts and blowing it into the house. Would appreciate some feedback on this.
Old 4/24/07, 12:52 AM
Jason1's Avatar
Jason1 Jason1 is offline
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Furnace Location?
Not a problem.
Old 4/24/07, 1:04 AM
Jason1's Avatar
I would add that the ductwork has to be sealed. Also, protection from impact wouldn't be a bad idea.
Old 4/24/07, 1:21 AM
Jason1's Avatar
I would also add that although it isn't a problem building code wise (check your local codes) I wouldn't do it in my house
Old 4/24/07, 10:33 AM
Charley L. Bottger's Avatar
Furnaces of all types are installed in garages all the time the returns are a sealed system back to the living areas. Return air can not be taken from a garage. When I inspect these types of installs I just ensure that the return air is properly sealed on the garage side. Probally 50 million units installed in this manner??????
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 4/24/07, 12:37 PM
David A. Andersen's Avatar
Insure that the duct does not break the fire wall barrier between the house and the garage. Flexible duct cannot be used in this application. Sheet metal duct of the appropriate thickness (set by code ) is required.
Old 4/30/07, 7:31 PM
gbrasseur's Avatar
gbrasseur gbrasseur is offline
Please Note: gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good point David.
Furnace Problem Comments Welcome rfrost Inspecting HVAC Systems 24 10/21/07 7:26 PM
Sweating decision:Settle for lower SEER to use existing furnace? Fel Randolph Inspecting HVAC Systems 2 6/6/07 3:56 PM
Correct connect at Furnace tmartens Plumbing Inspections 2 5/1/07 10:33 PM
Armstrong Ultra 80 Oil Forced air furnace Stephen Frazer Inspecting HVAC Systems 19 4/9/07 9:00 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
