Old 12/28/11, 4:56 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Furnace mounted humidifier
The furnace mounted humidifier had the water line feed connected to the hot water line from the water heater. Should it be on the hot side, cold side, or does it matter?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/28/11, 5:01 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Default Re: Furnace mounted humidifier
I would say cold. Lets see what the experts say...
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 12/28/11, 5:04 PM
James H. Bushart's Avatar
It should be removed, IMO.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 12/28/11, 5:20 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
I would say the same as James!
Reason is it is a breading ground for bacteria. According to knowledge humidifiers should be cleaned at least weekly and you will never find them clean unless they are the type with self-clean features. Hot water would be worse and create even more bacteria in the water tray containment area.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/28/11, 5:57 PM
Roy D. Cooke, Sr's Avatar
Originally Posted by jbushart View Post
I agree .
In Canada we need dehumidifiers most of the year .
Humidifiers are a great place to breed bugs and the whole Family has no idea why so many are sick so often .... Roy
Old 12/28/11, 6:08 PM
Bill Smith's Avatar
Excellent responses - Thanks!
631-434-5200
Old 12/28/11, 6:31 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
I agree with the negative assessment of humidifiers - they create more problems than they are worth. But you will find a lot of them plumbed to the hot water under the assumption that more water will evaporate. In practice, the water cools faster than it is used.
Chad Norlen
SEI Inspections
Certified Professional Inspector
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 12/28/11, 9:57 PM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
If you have a whole house humidifier installed, be sure it is on the return air ducting. It is never a question of if a humidifier will leak, but when. If installed on the supply ducting the leakage will be onto the heat exchanger causing rust and premature deterioration potentially allowing combustion by products into the home. Newer high efficiency heat exchangers are constructed with stainless steel and designed to cope with condensate but still not a good idea to rain water down onto the thing.
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Old 12/29/11, 10:31 AM
David A. Andersen's Avatar
Chad, Thank you for answering the asked question!
Hot - Cold water supply does not matter for most humidifiers.
Some steam generator types back flush and use a lot of water at one time and may effect the sensors, but the other kind never see the water hot.
BPI# 5015804
Old 12/29/11, 12:25 PM
Bill Smith's Avatar
Thanks to all who responded. Based on what I read here, I think it would be best to yank the humidifier and explore other options. Happy New Year!
631-434-5200
Old 12/29/11, 12:42 PM
Michael Larson's Avatar
Hot side is better as it will vaporize more readily than cold water.
Some might think it best to remove the humidifier but that is wrong for my area.
We heat very cold air here and without some humidity it becomes very uncomfortable and you have a lot of static electricity build up.
It is important to control the level of humidity as the temps change throughout the season to prevent condensation on windows and frames.
This can be done manually but an automatic system that senses outdoor temps is more reliable.
Michael Larson
Hudson, WI
Old 1/3/12, 11:01 PM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with ALL that Michael (as long as the hot water hasn't passed through a water softener)
Maybe it depends on the region but many humidifiers in my area are operating on hot water because it increases the humidifying capacity so much.
The down side is 1) a little more lime/calcium build up to clean out of the orifice at the annual fall start up than there would have been with cold water and 2) Self cleaning humidifiers do run a little water down the drain when operating in order for them to be self cleaning and it does cost a little to heat water then run it down the drain but that is really pretty minimal. The main thing is that there is no water left in them when they turn off so no weekly cleaning necessary.
Most of the old time humidifiers had standing water in them and did need constant cleaning so I think that left bad impressions on folks that now say all humidifiers are included in that group.
The author in that link that James provided evidently was thinking along the same lines since the picture in the link was one of those old style humidifiers with the little cesspool.
A good self cleaning humidifier such as General or Aprilaire for example will not have bacteria and will only need maintenance once a year at start up.
I realize that many things are different in different parts of the country, so what works great here in the Midwest may not necessarily be the best way to do things in other regions.
Need Date of Lennox Co Furnace (SR? 00 or 01 ?) Ja Florian Inspecting HVAC Systems 1 3/28/11 12:14 AM
Humidifier on electric furnace jprince1 Inspecting HVAC Systems 11 6/11/09 9:08 PM
H2O heater and furnace wall mounted? moliver General Inspection Discussion 1 7/9/06 7:31 AM
