Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
I know you will answer "it depends" but I am looking for an order of magnitude. How much electric power does a gas furnace need to light (I have a spark thing) and operate the blower? I am thinking of buying some power back-up to run the heating in time of emergency and was thinking of how much oomph I would need.
Are we talking hundreds or thousands of watts? And what happens to a gas furnace that is burning when the power is cut? When the blower goes off, does the furnace? |
Approximately 746 watts for each Horse Power of the blower motor.
3/4 HP would be 560 watts But start up current of the motor is higher. |
Ian,
I assume you are working with an Electrical Contractor to help size and install this aux. generator? I am also thinking you will be operating more than just the Furnace in an emergency situation, with this aux. system? I would guess that a newer furnace will probably require no more than 6-10amps to start/operate. I agree with Charley, damage can be done to gas furnaces that are short cycled off during a power outage, especially on a frequent basis. It can also be a fire hazard if there are any defects in the furnace, that might be unknown. Good Luck finding the right Electrical Contractor |
Too much power, and too complicated. I'll give up and use blankets instead. It was just an idea.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 2:56 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| question on wireing furnace, legal or not | Bill Hathaway | Electrical Inspections | 26 | 1/19/07 10:36 PM |
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 10:06 AM |
