Old 1/6/07, 10:00 AM
Jeff Connors Jeff Connors is offline
Please Note: Jeff Connors is a non-member guest and is in no way affiliated with InterNACHI or its members.
Question Furnace Questions...
Our gas company refused to turn on our gas because the chimney needs a liner. Is this something they can refuse just because of a liner? The home is over 100 years old and it may need a liner or new furnace but I don't think this is an emergency. The chimney is not leaking.
Can anyone tell me how old my furnace is? It's an Armstrong gas forced air, model G531400 4AE37, Input: 140,000 (BTU rating?), Bonnet Cap: 112,000, Ser #R110287.
If I do need a liner, my decision will be to install a liner for $xxx or to install a new furnace that vents directly outside through a side wall and not vent through the chimney. I don't want to spend a lot of money on a liner only to replace the furnace in a year or two. Any educated opinions? Thanks!
Jeff
Old 1/6/07, 1:47 PM
rsummers rsummers is offline
Location: 13302 Cabin Hollow Court Suite 110 Chico, CA 95973
Please Note: rsummers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Furnace Questions...
If there is nothing else being vented in to old fire place chase extend the flue in approved type B vent all the way up chase until it exits the top. The furnace should not be venting in to old stack anyways the gas will condenses in the stack before it reaches the outside and can cause condensation and other issues.
Old 1/6/07, 3:24 PM
David A. Andersen's Avatar
Yes, it happens all the time.
Just do as Rolland posted and you will be up and running.
Old 1/6/07, 8:02 PM
Jason1's Avatar
Jason1 Jason1 is offline
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't know how old your furnace is, but depending on where you live and how big your house is, it may be worth installing a high efficiency unit that is direct vented - fuel savings alone will pay for the extra cost. Also, unless you live in a massive size home, 140,000 BTU is too big.
Old 1/6/07, 8:09 PM
Charley L. Bottger's Avatar
Apparently the part of the world you are living in Jeff is not the same as mine. ONG In Okla. Allows vents into a chimney liner or not and I agree with the other post you have to conform to the gas company rules or find a way around them as was suggested with the class B vent up the chimney. But If your chimney that is 100 years in age as some I observe in my area they have a offset near the bottom that can be kind of tricky building a offset into the vent pipe and lowering it from the chimney cap but that is the least expensive route to take.
Old 1/7/07, 1:22 AM
Russel Ray's Avatar
That's an odd serial number for Amstrong. Most are one letter, five numbers, three letters. Can you verify that number for us?
Over the years, Armstrong has been manufactured by various companies, but none of them use that specific type of serial number.
Old 1/7/07, 10:00 AM
David P. Valley's Avatar
Jeff
Prestons tells me that it's manufactured between 1972 and 1976. (M#G53140)
Old 1/7/07, 10:47 AM
rmusch rmusch is offline
http://www.mtlfab.com/metalfab/content/view/full/382
This link will take you to metal fabs website. Flexible liners work well and are o.k. with most local codes.
Old 1/7/07, 11:54 AM
Jason1's Avatar
Do yourself a favour and replace it with a high efficient - direct vent. Better move in the long run. IMHO.
Furnace Problem Comments Welcome rfrost Inspecting HVAC Systems 24 10/21/07 7:26 PM
Sweating decision:Settle for lower SEER to use existing furnace? Fel Randolph Inspecting HVAC Systems 2 6/6/07 3:56 PM
Correct connect at Furnace tmartens Plumbing Inspections 2 5/1/07 10:33 PM
Armstrong Ultra 80 Oil Forced air furnace Stephen Frazer Inspecting HVAC Systems 19 4/9/07 9:00 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
