Old 1/17/10, 7:29 PM
Casey Patten's Avatar
Casey Patten Casey Patten is offline
Default Furnace venting
Hi guys,
I've got a friend in Nebraska that's concerned about the venting of his new furnace (installed early 2009)...one contractor that bid it mentioned a city code of being too close to the gas meter...my thought was that it shouldn't be vented over a basement window! Comments? Thanks...
Root River Inspections
Serving Rochester, Winona, Red Wing, Austin, Albert Lea and all Minnesota areas.
Vice-President, Southern Minnesota Chapter of InterNACHI
Direct: (507)254.1391
Web: www.arochestermnhomeinspector.com
Email: rootriverinspections@gmail.com
"The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help'" - Ronald Reagan
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/17/10, 8:23 PM
James E. Braun, CMI's Avatar
Default Re: Furnace venting
If the window can be opened, the vent needs to be at least five feet away. I never knew there was a rule about gas meters. I am not much on codes.
Old 1/17/10, 8:50 PM
Jeffrey R. Pope's Avatar
The vent should be at least three-feet from the meter vent, but it appears as though it is. I've seen utility companies flag a condenser being that close.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/17/10, 9:35 PM
rbero rbero is offline
Send a message via Yahoo to rbero
I checked the code check 2006 and came up with this clearances are 10,000 btu is 6 in clearance from bldg openings -10,000 to 50,000 btu is 9 inches and 50,000 and up is 12 inches and only rule for placement is no termination where vapor would be a nuisance. So the meter idea may be bad cause the vapor may cause premature rusting of the meter the base ect. the window should be ok just check for clearances
furnace common venting Unregistered AskNACHI.org Inspection Questions Forum 2 11/5/09 10:02 PM
Draft induced furnace venting with water heater jprince1 Inspecting HVAC Systems 8 12/15/08 9:56 AM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
Pvc For Furnace Venting? dtaylor Inspecting HVAC Systems 8 8/11/06 12:11 AM
90% efficient furnace venting jrupert Inspecting HVAC Systems 2 2/16/06 4:54 PM
