This woodburner is vented into same unlined chimney as water heater and furnace, which I'm assuming is not correct, no? Additionally, the vent slopes downward??? Any helpful insight and/or narratives is greatly appreciated.
Furnace exhaust is pipe above. Water heater vents on the other side. |
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Josh, I found one of these last year. If it is wood burning it should be in a flue by itself, from what I got from the plumbers and heating guys I talked to.
Joshua, just type up what you just said!
They can't share the same chimney, and the flu angle is incorrect and the chimney is not properly lined. Technically, an unlined flu may be red tagged and the gas supply locked off by the gas company until compliance is achieved. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
In Canada, you may vent oil and wood boilers/forced air furnaces into the same flue if the appliances are certified for use with each other and are vented from the same house level. You can not vent an oil water heater into that flue. A wood stove cannot, at anytime, be vented into a flue serving an oil appliance. |
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 24 | 10/21/07 7:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 3:56 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 9:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
