dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
I searched the boards but didn't find much regarding galvanic corrosion so thought I would post my question here.
What do you think the likely cause of this galvanic corrosion is from??? I suspect condensate running back down the flue but want someone a little wiser to confirm this or steer me in the right direction. Thanks, Dave |
| Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Galvanic corrosion is caused when dissimilar metals are in contact with one another either directly or through an electrolyte.
What you have is simply corrosion. It could be from condensation or could be from water entry. Why not just report what you know to be factual. i.e., that the vent is corroded? Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Chuck's right and so are you, David. It's not galvanic, it's caused by condensation and that white powder is typical evidence of a flue that's too long, has too many bends, or has inadequate slope.
Thanks Kenton. And Chuck, no kidding, what do you think I did? But thanks for the response just the same.
Dave |
| Total galvanic reaction? | jtribuzio | Plumbing Inspections | 19 | 4/3/10 2:18 AM |
| Corrosion at breaker connections | acatterton | Electrical Inspections | 6 | 10/27/08 6:28 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Soldered pipe supports causing corrosion | kshepard | Plumbing Inspections | 7 | 12/3/06 2:30 PM |
