Gas piping at today's inspection had about 20' of galv. piping, the rest of black iron. After researching, some say that it's not good because it can flake off, which clogs burners, etc. Some say that it's o.k. Opinions? Input?
I was going to say something along the lines of " not a recommended material due to the possibility of flaking which can clog lines, burners, etc. Consult with local building code authorities for more info.... etc. etc. Let me know what y'all have to say..... Thanks much, Josh |
What does the local gas company say about galvi piping? Some areas allow it.
May I chime in
Josh I think you are confusing galvanized iron pipe with copper I personally have never known galvanized to flake off and clog burners copper only. I was taught the reason not to use galvanized was it can be confused with galvanized iron water piping some home owner thinking the water was shut off and decided to cut the line whoops it has gas in it must be the wrong line. My local AHJ does not allow galvanized for gas but they over look a galvanized fitting some home owner may have made repairs with but on new construction no galvanized allowed. As an inspector I follow the same. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| copper galvanized direct contact? | jjones2 | Plumbing Inspections | 4 | 4/9/08 11:15 AM |
| Fire sprinkler systems, galvanized pipe? | jmerritt1 | Plumbing Inspections | 3 | 4/6/07 7:54 PM |
| Copper Connected to Galvanized | twheeler | Plumbing Inspections | 11 | 4/5/06 11:07 PM |
