Cat 4 furnace with schedule 40 running through to the outside.
Is this OK in light of what I found below? R309.1.1 Duct penetration. Ducts in the garage and ducts penetrating the walls or ceilings separating the dwelling from the garage shall be constructed of a minimum No.26 gage sheet steel or other approved material and shall have no openings into the garage. Also have a vent from the furnace on the other side to the garage but it has a automatic Honeywell damper control,so is that OK? |
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Schedule 40 is not a "duct". As long the opening is properly sealed it should be OK.
Building standards require that all ducts in the garage and ducts penetrating the firewall be equipped with fire-dampers or constructed of a minimum of No. 26 gauge sheet steel or other approved material and shall have no openings in the garage. This condition compromises the garage firewall system. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| Garage floor same level as house a safety concern? | thorn2 | General Inspection Discussion | 11 | 1/25/10 3:33 PM |
| Garage door opener Question | dnasser | Exterior Inspections | 2 | 11/10/09 8:45 AM |
| another question on detatched building? | dokeefe | Electrical Inspections | 7 | 9/14/09 10:30 AM |
| Garage / Apt separation | Carol Jones | Structural Inspections | 1 | 6/14/09 7:56 AM |
| Room Under Garage Question? | rfrost | Structural Inspections | 7 | 7/10/07 2:00 PM |
