I was visiting a friend in Florida, just outside Orlando, last week.
I noticed that the gas water heater was sitting on the floor with a drip tray under it. I was under the impression that gas water heaters had to be 18" off the floor when installed in a garage. Is this true? Why would anyone put a drip tray under the heater in a garage? Just curious Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
The newer units have a sealed compartment for the ignition source. Many of the AHJ's are allowing these units to be set on the floor. That might be what you saw in Orlando.
The drip tray was added so that we could confuse the hell out of all of the Canucks that visit. Greg Bell Titusville, Fl 02111507 Serving Central Florida
"Click to Enlarge" Attachment 8938 Last edited by dvalley; 10/7/07 at 4:42 PM.. |
Dave:
Thats what I thought but Greg is the Code guy. I can see the point of a drip tray in an attic or closet but the garage seems a little over the top. Oh well. Thanks for the input Cheers </IMG> PS His car is grey, or is it gray Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
I believe another reason for the fuel burning device to be raised above floor is to help protect it from mechanical damage
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
David what source do you use for your illustrations
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
| Client wants a new water heater | adirienzo | General Inspection Discussion | 47 | 7/14/10 2:03 PM |
| water heater recall | bwiley | Plumbing Inspections | 3 | 2/22/07 7:40 AM |
| Hot water heater question | mgeddie | General Inspection Discussion | 15 | 6/7/06 1:00 PM |
| HVAC / Water Heater Flue | abishop | Inspecting HVAC Systems | 5 | 2/22/06 11:30 AM |
