The line has piping coming from two directions. The right
side is coming from the kitchen. The left side is coming from the garage. Is that ok? The other thing is the pipe is galvanized, ( not the black gas pipe). Is the black gas pipe a requirement also ?
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It is acceptable in rural Missouri. Now California may be different.
Galv is ok in CA.
I think you'll find that one of those is a continuation or a feed to another appliance. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
What is your actual concern ?
If it's supported properly, it should be fine. It looks like just a 'T' coming off the gas run. Also, if it's galvanized, I would recommend having a drip leg near that shut-off. In case of flaking inside the pipe.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Is the dryer gas line ok...serviceable. Or is the construction a defect.
thanks....
| Dryer Vent Repair Montgomery County | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/12/09 9:22 PM |
| Dryer Vent Repair Chester County | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/12/09 9:21 PM |
| Dryer Vent Cleaning Philadelphia PA | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/11/09 12:24 PM |
| Dryer Vent Cleaning Delaware County PA | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/11/09 12:22 PM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
