Interesting place for a soup can.
Jason Raddenbach is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have seen a firepalce damper similar to this but the soup can had been cut off already. Here is a link to the photo taken of it. you can see the ring left on the damper from the soup can. In this image the fireplace damper is a gas fireplace and it has the clip on it to keep the damper open. http://www.chimneyballoonusa.com/blo...mney-flue.html
I believe the soup can is a weight that is intended to keep the swivel type damper closed so downdraft winds in the fireplace chimney do not blow it open on accident. |
| Gas log insert damper | lbrown2 | Inspecting HVAC Systems | 12 | 9/18/08 6:07 AM |
| Fireplace damper does not close completely | psiposs | Ancillary Inspection Services & Additional Topics | 15 | 7/31/08 4:47 PM |
| The Rumford Fireplace: Safety vs. Efficiency | mbryan | Interior Inspections | 2 | 4/28/08 4:38 PM |
| Soot from Barometric Draft Damper (posted by Ted Hull) | AskNACHI.org | AskNACHI.org Inspection Questions Forum | 3 | 5/11/07 6:49 AM |
