The flexible connector used to supply this gas furnace is much in excess of 6 feet in length, and the gas shut-off valve is about six feet away. Is this excessive? I thought 3 feet was the max?
Andrew Dooley Dooley Home Inspections LLC Broken Arrow, OK 918-955-0525 andrew@dooleyinspections.com |
Maximum 3' except for range or dryer. You also have the problem of the flex passing through the appliance housing.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
http://www.gastite.com/homepage.php?pg=inspectors
CSST can be used instead of black pipe. It's getting popular, so you may see it more often on newer homes. It's cheaper and easier to install, so long as it is properly supported. It can, in some jurisdictions, go throught the cabinet if it is protected with a proper bushing. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Thanks Steven I thought 3' was the max and also thought it needed to be hard piped through the cabinet. Thanks for the website Jae, this is indeed CSST, but there is no bushing where it goes through the cabinet though. I guess there is no length restriction on CSST? Is there a maximum distance away the gas shut-off valve is allowed? Again 3' comes to mind.
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 28 | 10/21/07 6:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 2:56 PM |
| Correct connect at Furnace | tmartens | Plumbing Inspections | 2 | 5/1/07 9:33 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 8:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
