Old 10/18/09, 9:13 AM
Default Gas furnace question
A family member's home...
When the thermostat calls for heat the draft inducer fan comes on but that is it...it runs continuously and nothing else happens...the igniter doesn't glow, the burners don't ignite, etc.
Chimney's not blocked and the vacuum hose isn't cracked.
Any ideas before calling a service tech?
Thanks.
Larry Kage, CMI
231 929 3525
Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America)
Old 10/18/09, 9:36 AM
Andrew Shick's Avatar
Andrew Shick Andrew Shick is offline
Default Re: Gas furnace question
It's not making the diaphram switch that proves that the draft fan is operating - could be a bad diaphram, or if it's a condensing furnace, the drain line could be clogged, and the trapped water could be slowing the fan enough to keep it from making the switch.
“Of liberty I would say that, in the whole plenitude of its extent, it is unobstructed action according to our will. But rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual.” - Thomas Jefferson
Old 10/18/09, 10:11 AM
Thanks Andrew, I'll check the hose and diaphram areas again.
It is not a condensing furnace...it's 80% plus Rheem about 20 years old.
I'm off and will check back later.
Larry Kage, CMI
231 929 3525
Old 10/19/09, 12:43 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could be the draft pressure switch, the pickup port for the draft switch restricted or plugged, inducer wheel for draft switch dirty or rusted away, inducer running slower either through bad bearings or a lower voltage being applied or a split in the heat exchanger.
Old 10/19/09, 1:32 PM
Thanks, Gary, I'll check what I can this afternoon.
Larry Kage, CMI
231 929 3525
Old 10/19/09, 9:26 PM
Thomas G. Valosin Thomas G. Valosin is offline
And, when all is said and done and a qualified individual services and repairs as necessary - remind them that gas fueled combustion equipment should be serviced at a period not exceeding 2 years. Maybe something just gave up the ghost but it does not sound like a routine maintenance program has been in place.
Old 10/19/09, 9:30 PM
It has been maintained but thanks for the thought.
Larry Kage, CMI
231 929 3525
Old 10/19/09, 10:28 PM
James E. Braun, CMI's Avatar
Does the gas control valve make a clicking noisy?
Old 10/24/09, 6:37 AM
Henry Martinez Henry Martinez is offline
Please Note: Henry Martinez is a non-member guest and is in no way affiliated with InterNACHI or its members.
Call a qualified tech to make sure it is safe to operate rather than resetting any safety for sake of thinking its safe to operate.
Direct vent oil furnace question Bart Connors Inspecting HVAC Systems 6 7/29/08 8:55 AM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
Furnace Problem Comments Welcome rfrost Inspecting HVAC Systems 24 10/21/07 7:26 PM
To hot too test the furnace rcooke Canadian Inspectors 1 8/19/07 11:44 PM
Furnace Question ccrooker Canadian Inspectors 8 10/26/06 10:15 PM
