[FONT='Verdana','sans-serif']This installation does not look right ( amount of bends in flue pipe) to me, and I am not finding anything in the code book to help me. Any help or comments (about flue pipe)would be appreciated.[/font]
Steve McIntire, Inspector EEinspections.com |
Looks a little funky to me as well.
It appears the contractor used single wall ductwork from furnace draft diverter collar to (I hope) double wall B'vent piping that runs up and thru to the attic area, and then out thru the roof. The connector used to join both vents appears to be a a bullnose increaser wye. Most Municpal inspectors in my area would laugh, and then make the contractor replace that fitting with a flow design fitting. I'd write it up for a prof. HVAC contractor to inspect and rework. Oh... tell your client not to use the orig. contractor, he'll say everything is A-OK. |
If you know who the manufacture is then their directions should give you the information needed .
I am with both the above posts does not look correct and do not ask the instaler. .......... Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Is that an up flow unit, is there an A/C coil below, I don't like the filter on the outlet of the unit, among other things
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
| Vent for Electric Furnace?? | mlong | Inspecting HVAC Systems | 5 | 11/7/07 10:16 AM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 10:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
| Hart & Cooley plastic furnace vent | apfaff | Inspecting HVAC Systems | 2 | 8/15/06 4:20 AM |
