I have a question about how I should write this up. We don't find a lot of gas furnaces and water heaters in the south. I ran across a gas furnace in a crawl space today. The vent pipe fed into a masonry chimney. In the garage a gas water vent also vented into the side of the chimney above the furnace vent. I believe the two are tied together but can't confirm because it is behind the masonry. Out of the top of the chimney is a single metal flue.
Any thoughts? |
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
General Notes:
- All Chimneys and Flues should be inspected and swept on an annual basis with use. - It is recommended that a Level 2 Inspection of the chimney / flue be conducted at this time (prior to closing) in accordance with the NFPA standard. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I occasionally see double wall class B running the full length of a non-lined masonry chimney which is allowed in this State
I would call out the flex going through the knockout and recommend a better support strap for tht B vent as they are using wire.
If it's vented into the chimney it's not allowed and the appliances should be checked for spillage. If the pipe is using the chimney as a chase that's fine but there is often sheetmetal to close off the top of chimney and prevent debris and moisture from getting in.
As far as the flue is concerned you can't report on what you can't see. There is either a wye-connector and a metal flue running the length or there is not, but you can't confirm it either way.
I think the most you could say is, (assuming this is true) "Cannot confirm proper venting of combined furnace and water heater. This is not a common installation in this area of the country and I recommend further evaluation to verify proper venting of gas burning appliances through the chimney." And you could also say nothing, or "Chimney flue not fully visible." Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
| Shared Venting gas boiler and water heater | ljansson | Inspecting HVAC Systems | 1 | 5/11/10 5:03 PM |
| Furnace/water heater venting | Dave Huss | AskNACHI.org Inspection Questions Forum | 3 | 12/17/09 5:03 PM |
| Water Heater / dryer venting | kweiss | Plumbing Inspections | 5 | 11/10/09 10:02 PM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
