Old 8/20/08, 12:16 PM
cfryar cfryar is offline
Default gas heating unit inspection
Dear Nachi,
I just inspected a four year old home and have a question regarding a gas heating unit that would not engage. All elec. breakers and disconnects were ON, the air conditioning worked fine but the gas heat would not come ON. I waited for about twenty minutes in case there was a delay but to no avail. The gas utility was ON.
The outside temperature was 91 degrees F. Is it possible that there is a limit switch that prevents the unit from engaging at this temperature?
Any ideas as to the cause of this condition?
Thanks,
Charles Fryar
WARNING: This e-mail is a suspected phishing scam.
Old 8/20/08, 2:23 PM
Stephen W. Stanczyk's Avatar
Default Re: gas heating unit inspection
What did you adjust the thermostat to?
Stephen Stanczyk
Old 8/20/08, 2:30 PM
Michael Larson's Avatar
Originally Posted by cfryar
Thanks,
Charles Fryar
Charles, Are you aware this appears on all your posts?
Michael Larson
Hudson, WI
Old 8/20/08, 3:00 PM
Nachi says that this is their computer trying to determine if this is advertising. Thanks for the "heads up".
Old 8/20/08, 3:01 PM
I set the thermostat to 90 degrees which is the maximum setting
Old 8/20/08, 3:03 PM
You didn't say, so I will ask.
What was the temp in the area of the thermostat when you tried to run the furnace?
Michael Larson
Hudson, WI
Old 8/20/08, 3:05 PM
The inside temperature was 76 degrees
Old 8/20/08, 3:13 PM
A couple of thoughts.
Assuming the gas was actually on in the home, it's possible that there was no gas at the burner. It may take several cycles to purge the air out of the line. This can usually be determined by watching the ignitor (hot wire or spark) to see if they are trying to ignite the gas stream.
The unit may have gone into safety shut down if it failed to ignite.
This has to be reset if that's the case before it will try to light again.
There may be troubleshooting LEDs on the control board that could also tell you what's going on if you have the codes available.
Good luck.
Either way, the unit did not respond to normal operating controls. Write it up as tested and report your results and recommendation for needed action to resolve the issue.
Michael Larson
Hudson, WI
Old 8/20/08, 3:14 PM
Charley L. Bottger's Avatar
Did the combustion blower motor ever energize if not it is probably locked out on a safety was the indicator light flashing on the control panel these can be reset by turning off the power supply and re activating.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/20/08, 4:52 PM
Gary T. Heller's Avatar
Pilot Light?
Old 8/20/08, 10:50 PM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could be one of many reasons why it didn't fire up.
Old 8/21/08, 1:00 AM
David A. Andersen's Avatar
No pilot lights on a four-year-old gas furnace.
A gas furnace has a whole series of stages it must pass through for ignition to occur. As posted, there are many reasons. Not to put you off, but you can't provide enough information for us to make an evaluation. Call the HVAC guy and have him let you know what was wrong.
BPI# 5015804
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
Ceilings falling with wires in it. jsmith3 Interior Inspections 9 3/16/06 7:24 PM
Russell heating unit rray Inspecting HVAC Systems 3 2/22/06 10:24 AM
