Old 10/22/10, 8:48 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Gas line Cut-off question...pic
The valve's were in the off position. Upstairs in the Attic is where the
heater was installed. Is this a gas cut-off? This would be a two story
townhouse in Southern calif.
If it is a gas cut-off, should I turn it on to check if the heater works? And
then turn it off again? Or should I say Standards of Practice do not let
me turned on valves in the off position....
Note..I tested for gas at the laundry gas valve...No gas.
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/22/10, 9:04 PM
James E. Braun, CMI's Avatar
Default Re: Gas line Cut-off question...pic
I would not. If it is an open pipe somewhere, you could blow up the house.
Old 10/22/10, 9:21 PM
Wayne B. Wilson's Avatar
If off leave it off, Ask why if anyone Knows, Note it. report it.
If your 100 percent where it goes just say it was in the off position. If your not sure then state unknown termination and advise a qualified contractor to investigate. Just my thought.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 10/22/10, 10:06 PM
Thanks....I think I will leave it and just note. Based upon your feedback
I think its off for a reason.
Old 10/22/10, 10:07 PM
Thanks Wayne...Im not a 100 percent sure. Im going to refer to a contractor.
like you mentioned.
Hot Liquid Line on AC krigler Inspecting HVAC Systems 19 7/17/10 8:00 PM
Gas line question acassady Plumbing Inspections 4 7/31/09 12:18 AM
Selected Electrical Incidents and Occurrences - First Quarter pabernathy Electrical Inspections 0 12/2/07 1:43 PM
Size of supply line aobrien Inspecting HVAC Systems 7 1/2/07 12:40 PM
