Old 10/25/07, 12:13 AM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
Please Note: Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default What is this on the gas line going to furnace?
All the years I was in heating and cooling and all the homes I inspected, I have never seen this before. A 9 unit building with all new furnaces and all but one gas line going to furnace had this installed. Can anyone tell me what it is?
Picture is not the greatest. It's black plastic with nothing going to it. You can slide it up and down the gas pipe and the two sides are held on by screws. It does have some weight to it.
Old 10/25/07, 12:19 AM
Kevin Luce's Avatar
Default Re: What is this on the gas line going to furnace?
Here are two more pictures.
Old 10/25/07, 12:23 AM
Michael Larson's Avatar
Magnet?
Old 10/25/07, 12:26 AM
Kevin Luce's Avatar
No.
It freely moves up and down a pipe but not large enough to slide over a gas shut off valve or a coupling if one was installed.
Old 10/25/07, 12:51 AM
What's the name on the side?
Old 10/25/07, 8:28 AM
Charley L. Bottger's Avatar
It looks like a safety clamp that can be used to clamp around the shut off valve in the gas line to prevent the valve from being closed or opened. We use to use red ones like that in my past life. I would have popped those screws out and had a look curiosity will kill the cat but satisfaction will bring it back.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/25/07, 8:51 AM
David P. Valley's Avatar
Hmmmmm. It appears to have a wire coming out of the first picture.
I would have removed the 4 screws. Now you've got me curious.
Old 10/25/07, 3:58 PM
Bob Elliott's Avatar
How odd as my first thought was magnets also.
Anyone notice how the coupling in the first picture appears to be galvanized?
(dis-similar to the black pipe)
Old 10/25/07, 4:04 PM
Kevin Luce's Avatar
Besides the screws, the rest of it is black plastic.
Old 10/25/07, 4:21 PM
David could not see any wire in the pic maybe my eyes are to old.
Will stay with my first thought a lock out device he did say this was a multiple unit and I was thinking rentals God only knows I don't.
</IMG></IMG>
NACHI Member
State License # 130
Old 10/25/07, 4:35 PM
Kevin I was refering to the gas pipe coupling.It looks like it is galvinized though it may be the pic.
Old 10/25/07, 4:55 PM
klott's Avatar
klott klott is offline
Could it be a bonding clamp of sorts? I noticed the wire also.
Old 10/25/07, 4:58 PM
rwand1 rwand1 is offline
Is it a protective cover which slips over the gas valve to prevent damage and/or someone inadvertently turning the valve off, such as children? Perhaps that is why its plastic, and slides. I think Charley is right.
Old 10/25/07, 6:16 PM
klott's Avatar
Maybe it is an electronic device to keep up with how much gas each unit uses.
Kevin Luce's Avatar
With the suggestions, I'll have to go with preventing the tenants from turning off the shut off valves. I would think there was a better system then just 4 screws.
Furnace Problem Comments Welcome rfrost Inspecting HVAC Systems 28 10/21/07 6:26 PM
Sweating decision:Settle for lower SEER to use existing furnace? Fel Randolph Inspecting HVAC Systems 2 6/6/07 2:56 PM
Armstrong Ultra 80 Oil Forced air furnace Stephen Frazer Inspecting HVAC Systems 19 4/9/07 8:00 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
