Old 4/16/08, 4:27 PM
Skip Erwin Skip Erwin is offline
Please Note: Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Gas Line Issues?
It's hard to tell from the picture, but the dirt leg is below the top level of the drip pan. Also, the gas line is in contact with the top edge of the drip pan. Is this OK? If the drip pan fills with water the gas line dirt leg will be under water. The edge of the drip pan isn't sharp, but its still a metal surface with an edge. Thanks in advance.
Old 4/16/08, 4:30 PM
Default Re: Gas Line Issues?
valve is on the wrong side.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 4/16/08, 5:18 PM
Bob Elliott's Avatar
Water contact to the gasline would be the least of your worries
Old 4/17/08, 6:43 PM
Jeffrey R. Pope's Avatar
I don't see that. The valve is required to be "before" the appliance connector, which is what I see. The appliance connector should not be in contact with the drip pan.
The drip leg is not an issue in my opinion, however, the entire installation appears to have been done by someone other than a professional.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/17/08, 6:54 PM
Charley L. Bottger's Avatar
The drip leg is suppose to be after the shut off valve so that it can be cleaned without shutting the gas off to the home just the appliance. Very shoddy install
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 4/17/08, 7:07 PM
Makes sense, but I've never seen it done like that. Admittedly however, I've only seen 3 or 4 drip legs in my entire career.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/17/08, 11:06 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anyone recommend retrofitting of them if the house was built before code called for them?
Old 4/18/08, 12:25 AM
If you're referring to drip legs, they are not always required. The utility company generally has the authority to either dismiss or require them.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/18/08, 1:11 AM
An older house needs them even more.
Hey Charlie...
Why shut off the gas when you can blow out the drip leg with the 3 pound gas pressure.
Old 4/18/08, 4:07 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Drip leg needs to be at the bottom of a vertical to actually catch dirt. Valve is before dirt leg and union to isolate appliance.
Simplified drawing. Not a good idea to put gas line in drip pan, but I can't find a specific code violation there, doesn't mean there isn't one. I would try to keep the gas line as dry as possible.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 4/18/08, 11:51 PM
I see guys use both the term dirt leg and drip leg both meaning the same thing. I don't know if all areas have the same problem as we do here in Ok but the term dirt legs for us does not necessarily mean trapping solids as we have a high content of moisture with the gas and the dirt leg is intended to trap moisture more so than solids. The AHJ is very stringent on dirt legs in this state. Drip legs can not be installed on a exterior or the attic gas line where the trapped moisture can freeze and or bust a line such as on a gas fired package unit or a horizontal gas unit in the attic.
NACHI Member
State License # 130
Old 4/19/08, 12:02 AM
Brian E. Kelly's Avatar
One, why would anyone live where the attic could freeze if there wasn't skiing nearby? That is just silly.
Two, who said the black iron pipe is not the entry line into the furnace?
Old 4/19/08, 7:31 AM
Barry Adair's Avatar
According to Sir Paul, this is the new "dirt leg" code labeling
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Got a letter from ASHI's President today. gromicko General Inspection Discussion 55 12/12/10 11:51 PM
Selected Electrical Incidents and Occurrences - First Quarter pabernathy Electrical Inspections 0 12/2/07 1:43 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
