Old 10/25/11, 7:48 PM
Kerri L. Grabowski Kerri L. Grabowski is offline
Default Gas line from meter to interior of home
Can a gas line from the exterior meter to interior of home be buried under soil or grade level deck or in contact with soil? Line is galvanized.
I suggested that it be re-routed...
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/25/11, 8:03 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Default Re: Gas line from meter to interior of home
Why not? Isn't the gas line underground from the street to the meter?
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 10/25/11, 8:08 PM
But I must confess , I don't recall seeing a gas line from a meter to house going under ground.
David
518-505-8305
Old 10/25/11, 8:09 PM
Then why is it 99% of the time you see gas lines FROM the meter to the interior of the home above grade?
Old 10/25/11, 8:28 PM
It depends on what is being used. (Galvanized is a no go.)
2003 International Fuel Gas Code:
404.8 Protection against corrosion.
Metallic pipe or tubing
exposed to corrosive action, such as soil condition or moisture,
shall be protected in an approved manner. Zinc coatings (galvanizing)
shall not be deemed adequate protection for gas piping
underground. Ferrous metal exposed in exterior locations shall
be protected from corrosion in a manner satisfactory to the
code official. Where dissimilar metals are joined underground,
an insulating coupling or fitting shall be used. Piping shall not
be laid in contact with cinders.
404.8.1 Prohibited use.
Uncoated threaded or socket
welded joints shall not be used in piping in contact with soil
or where internal or external crevice corrosion is known to
occur.
404.8.2 Protective coatings and wrapping.
Pipe protective
coatings and wrappings shall be approved for the application
and shall be factory applied.
Exception:
Where installed in accordance with the manufacturer’s
installation instructions, field application of
coatings and wrappings shall be permitted for pipe nipples,
fittings and locations where the factory coating or
wrapping has been damaged or necessarily removed at
joints.
Larry Kage, CMI
231 929 3525
Old 10/25/11, 8:37 PM
Gary D. Rowden Gary D. Rowden is offline
It’s done here in Southern California, I see natural gas meters next to street or edge of property line (some in vaults and some not) with underground supply lines to home quite a bit. Of course you want to check with any requirement or codes regulating running a natural gas line in your area.
Old 10/25/11, 8:43 PM
http://www.engineeringtoolbox.com/ap...es-d_1112.html
Old 10/25/11, 9:24 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Good Info Marcel:
I am not sure what kind of line you are talking about so just to be sure I am adding this.
Gastite
®/FlashShieldCSST shall not be buried directly in the ground or directly embedded in concrete (e.g. slab on
grade construction, patio slabs, foundations and walkways). When it is necessary to bury or embed
Gastite
®/FlashShieldCSST, the tubing shall be routed inside a non-metallic, watertight conduit that has an inside diameter
at least 1/2 inch larger than the O.D. of the tubing (Fig. 4-85). For ends of the conduit installed outdoors, the conduit shall be sealed at any exposed end to prevent water from entering.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/25/11, 10:20 PM
Barry Adair's Avatar
this may help...or not...you'll have to scroll for install diagrams and info
i'm with no go galv but what do i know about Mb
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/25/11, 11:49 PM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
Great read, there is an excellent diagram on page 82.
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Old 10/25/11, 11:55 PM
Roy D. Cooke, Sr's Avatar
Good info Thanks... Roy
New Alberta home inspection regulations rcooke Canadian Inspectors 13 8/31/11 1:30 PM
Home Inspector Listings Part Two jbowman Miscellaneous Discussion for Inspectors 8 8/29/06 8:52 PM
