jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
y....
So why would the pilot light be lit if the gas line shut off valve is in the closed position? Only thing I can think of is that the shut off valve is faulty and is not doing a proper job of shutting off the gas in the line. I would be interested in other interpretations or explanations. Thanks! Jeff |
faulty valve, what the flex pipe throught the cabinet?
We live in earthquake country. flex pipe is used around here. |
We use it here too, but it is not supposed to go thru the cabinet. It seems to me this would be more important in an earthquake prone area. |
Can the valve handle possibly be removed and put back in the wrong position and the valve is actually still on, one would need to see it for certain, I cannot tell from the picture if the handle can be removed, some of them can....or the valve is shot. Most likely the valve is shot I would think. |
Does the appliance operate??????
No....it does not operate. Burners never lit. I thought about the valve handle being in the wrong position but looked closely at it and it didn't appear to be. Everything is old in this home (built in 1939) so I didn't dare touch the valve. Gas furnace built in 1976 so I am recommending cleaning/servicing and further evaluation of the burner components and heat exchanger by a qualified HVAC technician. |
[quote=jweinberg]I thought about the valve handle being in the wrong position but looked closely at it and it didn't appear to be. Everything is old in this home (built in 1939) so I didn't dare touch the valve.
Gas furnace built in 1976 so I am recommending cleaning/servicing and further evaluation of the burner components and heat exchanger by a qualified HVAC technician.[/quote] Further evaluating....is a good choice of words...... If it was mine....it would be replaced...... I had a old home here we were flipping, the gas valve was an antique, the handle could be removed and put back either up down or sideways, thats why I asked. When I was messing with the valve trying to turn it off, the pressure in the pipe from the valve to the furnace kept the pilot light lite for some time, until I figured out which way off was. There were not any visible arrows on the valve so it was trial and error, funny you should ask about the thing still being lite...made me remember about that fiasco...... |
[QUOTE=dduffy]
Weird how you see things in the field that you experience in your own life. However, I'm still waiting to find another house with small gauge, single strand aluminum distribution wiring like I have in my home. I think I must be the only one in town. I plan on getting the Copalum Crimp remedy someday. |
You need to find a friend who is an electrician......man that helps...... And a friend who is a HVAC tech....... |
The Remaining Gas In The Line After The Shutoff Will Feed The Pilot For A Substantial Amount Of Time
Owner of the home says that he didn't turn off the valve (but he seemed to be a couple sandwiches short of a picnic). The last time PG&E came out was in December. But the owner said he had run the furnace in January. I know...it just doesn't add up. They must have a basement ghost who decided to turn off the gas valve. |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
There are seals on those valves that go bad....when the seals go bad....liguid or gas can "weep" by....the seals can go bad for various reasons...I believe even a pin hole size leak would let the pilot stay lit....forever and ever amen.
Thanks to everyone. Seems like the consensus is a bad valve/seal.
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| Brilliant idea | jmichalski | General Inspection Discussion | 45 | 11/14/06 8:19 PM |
| How many forum members to change a light bulb? | kshepard | Miscellaneous Discussion for Inspectors | 9 | 8/2/06 10:56 AM |
