Old 3/16/06, 3:28 PM
David C. Macy's Avatar
Default Gas logs
Do these gas logs require a vented chimney?
It appeared that there is only one flue and a chimney liner is installed for the water tank & furnace.
I recommend evaluating before using add there was no tag for the log set.
Thanks
Dave
Old 3/16/06, 3:40 PM
Jeffrey R. Pope's Avatar
Default Re: Gas logs
It really depends on its listing, however, that does not look like any ventless log set that I have ever seen.
It appears to be a fairly standard (although low budget) log set which will produce a significant amount of carbon monoxide.
Even the "ventless" type warn that windows should be left partially open while in use. I wonder why
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/16/06, 5:28 PM
rmoore's Avatar
rmoore rmoore is offline
Please Note: rmoore is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's to allow easy entry for the paramedics.
Old 3/16/06, 6:07 PM
kfulton kfulton is offline
It is a Kevorkian fire place.
Old 3/16/06, 6:15 PM
rwand1 rwand1 is offline
It should be properly vented. Most gas log inserts into wood burning fireplaces should have the damper removed or a locking nut to keep the damper handle in the open position.
There are energy wasters in my opinion because the damper must be open when not inuse.
Old 3/16/06, 8:17 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I may be wrong but I am pretty sure the energy code requires that glass door enclosures be installed when the damper is blocked open. Anyone got accurate info about that?
Old 3/16/06, 8:22 PM
I don't do "Energy Code"
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/17/06, 6:54 AM
I have seen them both ways, doors, no doors. Some with the damper not blocked open. Even with glass doors the damper must remain open. Big energy waste.
Old 3/17/06, 7:54 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here's a web page of links to sites about "Vent Free" heaters and gas logs.
http://www.essex1.com/people/mechacc...Appliances.htm
Makes you wish the US would outlaw these devices.
Old 3/17/06, 9:35 AM
David P. Valley's Avatar
Ventless is not allowed in Massachusetts.
Good info. here...
http://hearth.com/what/gaslogs.html
Gas Logs........ pabernathy Inspecting HVAC Systems 11 12/25/06 9:58 PM
No hearth on gas logs kblair1 Inspecting HVAC Systems 9 12/21/06 5:21 AM
NG vs LP gas logs? bmargiotti Inspecting HVAC Systems 3 10/31/06 1:10 AM
Ventless Gas Logs Skip Erwin Inspecting HVAC Systems 5 7/7/06 3:33 PM
