Old 5/7/08, 6:39 PM
Andrew W. Hinz Andrew W. Hinz is offline
Default gas pipe clearance to flue?
Does anyone know the minimum clearnace of gas piping to a flue pipe? I had one today where the gas piping was touching the flue pipe. (see photo) I'm not sure of the proper clearance, but it didn't look good to me. Thanks
Old 5/7/08, 7:00 PM
Jeffrey R. Pope's Avatar
Default Re: gas pipe clearance to flue?
The flue (B-vents) generally requires clearances to "building materials," which would include piping. But it's not more of an issue simply because it's a gas pipe.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/7/08, 7:05 PM
Barry Adair's Avatar
As in clearance from the insulation and drywall and where is the fire-stop/flue collar?
What is the source of the moisture stain?
May have been trying for pre-ignition
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 5/7/08, 7:11 PM
This is a furnace flue pipe, not a chimney, so I wouldn't think it needs fire stopping, but yes, I did note that is was touching attic insulation. (1 inch minimum to combustible materials) My specific concern was the gas pipe. I have never seen anything that requires a specific distance from a gas pipe, and maybe there isn't one, but it seems like there should be. I suppose I invision a gas leak that catches fire from the hot flue pipe. Yikes!
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 36 10/27/10 11:21 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 7:39 PM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
Oil Furnace Flue Clearance jfunderburk Inspecting HVAC Systems 3 2/28/06 8:17 PM
