Old 2/5/07, 11:49 PM
adooley's Avatar
adooley adooley is offline
Default Gas wall furnace
I will be inspecting a gas wall furnace tommorow. Anything I should think about in advance or be prepared to look for? Thanks for input!
Andrew Dooley
Dooley Home Inspections LLC
Broken Arrow, OK
918-955-0525
andrew@dooleyinspections.com
Old 2/6/07, 6:37 AM
David P. Valley's Avatar
Default Re: Gas wall furnace
I wouldn't inspect this furnace any differently than an average furnace.
Old 2/7/07, 12:58 PM
Charley L. Bottger's Avatar
Andy;
I pay particular attention to the clearance of the flue pipe pentration into the attic as I have discovered charred wall plates in the past very close to point of ignition.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/7/07, 6:19 PM
Andy
I'm with Charley, inspect the physical installation where possible and recommend a service inspect on the mechanics, unless the unit(s) are new. I've run into units where the flue vent materials have been modified to space allowed in framing, as well as gaspiping, cabinetry being cut, etc.
Old 2/7/07, 7:56 PM
Peter C. Russell's Avatar
I've seen these units vented thru the wall, check the clearance outside from the siding and if it has a blower make sure it's not near the vent. Any suspicions, defer it!
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 5:25 PM
Single wall furnace flue sspradling Inspecting HVAC Systems 8 6/29/07 7:23 PM
H2O heater and furnace wall mounted? moliver General Inspection Discussion 1 7/9/06 7:31 AM
