Old 2/10/06, 12:25 AM
hspinnler's Avatar
hspinnler hspinnler is offline
Please Note: hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default GE HVAC Age Code
I have a code list beginning with Amana and ending with York, but no GE appliances.
Can anyone tell me the date code on this AC unit M/N: BTN724A100A1 S/N: 452614T34 & this furnace M/N BLU080E942B1 S/N 54289T07. Home built in 1982.
(Now I see the "80" after BLU for the furnace. Could be a 1980. How about the AC though?
thanks,
Old 2/10/06, 8:24 AM
David P. Valley's Avatar
Default Re: GE HVAC Age Code
Hank,
The Furnace (M/N BLU080E942B1) was manufactured in 1980 it has a capacity of 80,000 BTU's.
The A/C unit (M/N: BTN724A100A1) is as follows...
If it has 24,800 BTU's it was manufactured in 1981
If it has 22,000 BTU's it ws manufactured in 1982
It appears to have 24,000 BTU's, so it's a 1981.
Old 2/10/06, 10:18 AM
hspinnler's Avatar
Thanks David. Do you have a reference sheet available for GE HVAC units?
Old 2/10/06, 3:10 PM
I used the Prestons Guide for your particular search.
Old 2/10/06, 7:37 PM
hspinnler's Avatar
That's some guide! Maybe I can ask for this set next Christmas.
Old 2/11/06, 6:10 AM
Russel Ray's Avatar
Originally Posted by dvalley
Hank,
I've never seen cooling capacity stated as BTU's. I believe BTU is a heating designation; cooling will be in terms of tonnage.
thanks,
The model number will not give you the manufacture date unless you know that a certain model was only manufactured in one year.
For General Electric, the date is coded in the last three digits in the serial number. The T in both instances here tell us that it was manufactured in 1960 or 1981. Logic and other facts (a 1982 house build) tells us that both are 1981 manufacture dates.
The model number will give us other information. For example, the 080 in the furnace model number does tell us that it is 80,000 BTUs. In the A/C model number, the 24 tells us that it is a 2-ton unit. FYI, one ton is 12, two tons is 24, three tons is 36, etc.
I actually find the Technical Reference Guide more valuable than Preston's Guide, but both of them together make a very good resource. You can find the Technical Reference Guide at About Homes in the Books and magazines area.
Old 2/11/06, 6:21 AM
Russel,
Please be more specific as to determining the age of GE HVAC.
Is there a formula (for GE) that you can post here?
Old 2/11/06, 7:04 AM
Russel Ray's Avatar
pp. 65-67 in the Technical Reference Guide. It's a spiral-bound paper book, so I don't anything to post. All things considered, the cost of the TRC is insignificant.
Old 2/11/06, 7:05 AM
Wrong...
The cooling capacity of A/C units is measured in tons, but my posting of BTU’s is simply reference material only. One ton of cooling equals 12,000 BTU’s or the amount of heat it takes to melt one ton of ice in a 24 hour period.
Tonnage-The unit of measure used in air conditioning to describe the cooling capacity of a system. One ton of cooling is based on the amount of heat needed to melt one ton (2000 lbs.) of ice in a 24 hour period. One ton of cooling is equal to 12,000 Btu/hr.
BTU- Most air conditioners have their capacity rated in British thermal units (BTU). Generally speaking, a BTU is the amount of heat required to raise the temperature of one pound (0.45 kg) of water 1 degree Fahrenheit (0.56 degrees Celsius). Specifically, 1 BTU equals 1,055 joules. In heating and cooling terms, 1 "ton" equals 12,000 BTU.
Old 2/11/06, 7:09 AM
I also have this same book. But I keep it in my tool bag to use on HI's.
I just thought you had a reference table that I could "copy and paste" into my files.
It would be great if someone had time to copy this info (from the book) onto this MB.
Thank you anyways.
Old 2/11/06, 10:42 AM
Russel Ray's Avatar
Wrong...
First, the fact that I have or have not seen something cannot in and of itself be wrong. You should have done a better job of cutting, pasting, and quoting.
Second, I had always wondered what "tonnage" meant and have never bothered to look it up. Thank you for the education.
Notwithstanding the fact that 1 ton equals 12,000 BTU, I've never found a licensed HVAC tech who talks about air conditioners in terms of BTU, only in terms of tons. So knowing that 12 = one ton, 24 = two tons, 36 = three tons, etc., is important. Knowing that the 12 = 12,000 BTU (and I'll take you word on all that; I'm still not going to look it up) is not necessarily as important in my eyes when discussing tons with my Clients.
The education of Russel Ray, however, is always important, and for that, I thank you again.
Old 2/11/06, 10:45 AM
Russel Ray's Avatar
Thank you anyways.
Could you not be that "someone" who has the time to copy the info from the book onto this MB?
Old 2/11/06, 1:41 PM
Ya know...I could give it a shot. I think it'll take me quite a while to get all that info. accumulated onto a document.
Maybe between you and I, we can get this accomplished. I'll do the first half of the book and you do the second half.
What do you say?
Hey, wait a minute...I just realized something.
You have speech recognition software, Right?
Well, how hard would it be to get this information onto a document by utilizing your speech recognition software?
Old 2/11/06, 2:06 PM
Russel Ray's Avatar
Voice recognition software, ability to talk, and/or ability to type has absolutely nothing to do with it.
Since the book is copyrighted, and Carson Dunlop, located in Canada, has not seen fit to allow me to publish their copyrighted materials at About Homes, I'll have to decline to post it here. Since the book is still in publication and for sale, that's only logical and to be expected.
That's why there is a link at About Homes for their Technical Reference Guide.
If I know something is copyrighted, then I endeavor to obtain permission from the copyright holder to post something somewhere. If I don't know that something is copyrighted, then I'll use it, and if it turns out that that something is copyrighted, then I'll deal with it appropriately upon notification. In this case, the Technical Reference Guide is copyrighted, and I know that, and Carson Dunlop has declined permission for me to post the information at About Homes and, guilty by association, of course, here.
I have no control over what other people do, or do not do, or post.
Old 2/11/06, 2:34 PM
Copywrite...smopywrite.
I have the gonads to post copywrited material here, so I think I'll get started on this.
Maybe Carson & Dunlop can approach me if they have a problem with me posting any of their reference material.
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
